Fixture File for Lanta - Saturn Cuboid
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
Hi Folks, I was wondering if anyone can please give me some help with these files. I have tried for a while but cant seem to get over this fixture has no intensity/dimmer function so I am obviously doing something wrong. Any help would be very much appreciated.
Saturn Cuboid.pff- (46.18 KiB) Downloaded 79 times
Lanta - Saturn Cuboid.ssl2- (7.06 KiB) Downloaded 70 times
l02214_cuboid_handbook.pdf- (1.04 MiB) Downloaded 86 times
Mac
www.mclite.co.uk
www.mclite.co.uk
- FreeStyler Version: Beta
Re: Fixture File for Lanta - Saturn Cuboid
Hej Uriahdemon
I had a quick look at the ssl2 fixture and can see that you uses the LED Panel with more beams.
I am not able to install 3D on the pc I have available at the moment so I can't verify your fixture.
Previously I have tried to get the LED panel with more beams to work but with no success.
I ended with creating a normal fixture only one beam.
To debug if this also is where you have the problem you can eventually try the same just building a fixture with one beam.
Looks like the multi beam is still an issue at nicolaudies easy view.
http://www.nicolaudie.com/forum_support ... ams#p48189
- Uriahdemon
Thanks very much, I will create something basic then.
Mac
www.mclite.co.uk
www.mclite.co.uk
Hej Again.
I played a bit with the FreeStyler fixture have a look.
- Uriahdemon
Thanks very much for the updated file............ very much appreciated mate !!!
Mac
www.mclite.co.uk
www.mclite.co.uk
