Blizzard Weather System 7ch mode
djdustin
FreeStyler Version: 3.6.3
Post by djdustin »
Enjoy!
Blizzard Weather System.pff
7ch mode
(94.57 KiB) Downloaded 27 times
Re: Blizzard Weather System 7ch mode
Post by Jan_K »
Just a small comment.
You have seen that there are a 7 and a 26 channel version in the complete fixture library.
viewtopic.php?f=23&t=4528 :)
djdustin
Post by djdustin »
Hey Jan!
Thanks For pointing this out. Oops. We never the profile and built this from scratch.
We'll make, sure to double check before posting. Just trying to give back.
You can delete this post if you'd like since it's a dupe. Up to you.
Post by Jan_K »
Hej djdustin.
I never delete posts :)
And it was just to tell you that there was an other fixture you may want to try.
I will add your fixture to the library.
Some prefer one fixture, some the other and they should have the possibility to make the choice on there own. :D
