Chauvet Intimidator Spot 355Z IRC
djdustin
FreeStyler Version: 3.6.3
Post by djdustin »
Enjoy Everyone! :)
15ch mode
Intimidator Spot 355Z IRC.pff
15 Channel Mode
(160.05 KiB) Downloaded 194 times
nouriel
Re: Chauvet Intimidator Spot 355Z IRC
Post by nouriel »
I installed the file for the 355z IRC but now i cant find it in freestyler to actually use it.
Post by Jan_K »
Under setup or ?
nouriel
Post by nouriel »
The thing is I bought the chauvet 375z irc and could not find it in the list of chauvet's lights in freestyler so I wanted to try to control the 375z irc with freestyler using the file for the 355z irc
Post by Jan_K »
I am not shure where you are looking but you need to add the fixture.
Setup-> Add/remove fixtures.
Find the Chauvet folder and search for the fixture.
Note somehow they are not listed 100% alphabetic. You may have to search the whole Chauvet folder to find it.
Return to “Chauvet”
