Fixture File VB2023 60W LUMILEDS LED DJ SCANNER Topic is solved
Rodrigo
Post by Rodrigo »
Hello! I need the fixture file VB2023 60W LUMILEDS LED DJ SCANNER
The example site is: http://www.goldbright.com.cn/info.asp?a ... 813&id=596
* High output creat a large wide powerful effects
* 4 digital display control board
* 9 channels DMX select from control panel
* Auto, sound active,DMX, Master/Slave.
* Color Wheel:7 Spilt Colors + White + Rainbow Effect
* Gobo Wheel:7 Static Gobos + Open + Rainbow Effect + Gobo Shake
* Shutter:0-13Hz
* Dimmer:Variable Electronic Dimmer (0-100%)
* Pan: 170 degree;Tilt: 80 degree
* Manual focus
* Power Supply: 100-240Vac, 50/60Hz
* Power consumption: 83W
* Light source: 60W High brightness White leds
* Dimensions:L525 x W275 x H460mm/2pcs
Please Help me!!
Nathanrs93
FreeStyler Version: None
Re: Fixture File VB2023 60W LUMILEDS LED DJ SCANNER
Post by Nathanrs93 »
No manual we can't help you.
