Looking for a Stairville MH-110 Fixture [SOLVED-ISH] Topic is solved
Just-Music
Post by Just-Music »
Do anyone of you have such a fixture?
Just-Music
Re: Looking for a Stairville MH-110 Fixture
No One have such a fixture?
Post by Jan_K »
Hej Just-Music
It looks like you have to do it your self.
If you have the manual then it isn't that difficult.
You can eventually upload the manual here then I will guide you.
Just-Music
Hello,
thank you.
I tried by my self. Here are the result:
http://www.just-music-team.de/down/MH110.fxt
but some settings are not working in the Freeytyler e.g. The faders for dimming
Here is the DMX Table of the MH-110
http://www.just-music-team.de/down/dmx_table.pdf
It will be nice, if you could help
Post by Jan_K »
When you exchange fixture files then export the fixture file to pff format.
The fxt don't contain all information.
I had a look in the fxt file you have and you have given Intensity channel "11" it should have no "6"
In you MH110 Shutter channel and intensity channel is the same.
Channel 11 and 12 you place on 1st. and 2.nd colorch where you give them values and color icons.
You can eventually have a look on the wiki for more information.
Post by Jan_K »
Just-Music
Could you help me to crate the fixture?
Post by Jan_K »
I can help you a bit but on channel 11 but the color wheels I can't help you with.
The colors for channel 12 are not listed in your and this means you need to have the MH110 next to you and note all the values and colors for this channel.
I will have a look on the pff.
Post by Jan_K »
Here is what I can help you with.
The 1st. color wheel you have to fill in you self as you have the fixture and therefore can get the values for channel 12.
MH110.pff
(11.05 KiB) Downloaded 28 times
