HELP! Freestyler lost everything! Topic is solved
woolpacklive
Post by woolpacklive »
Today I have a nightmare i loaded freestyler to find everything had gone.
No Fixtures, no Chases, no overides, nothing.
Yesterday i installed chamsys magicq software to have a look, dont know if thats relevant or not.
Has this happened to anyone else? is there a solution?
to reprogram everything would take a long time as my universe contains 10 moving heads of three different kinds, 6 scanners, and 8 moving led washes and strobe and smoke machine.
many thanks
FreeStyler Version: 4.01
Re: HELP! Freestyler lost everything!
Post by Partyman »
Your sequences and such should all still be in the folders in the "freestyler" root file on your c drive.
Unfortunately it is like most software in that data backup and file protection only becomes important AFTER you have had a failure.
Good Luck
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
As long as you saved your location in the freestyler file which is it's default you should be able to reload location that you save that show to.
