I can't add 2 interfaces in Freestyler 3.5.9. The software only recognizes 1.
Can you help me please?
Freestyler X2 Universe problem Topic is solved
- buttza
- FreeStyler Version: 3.6.4
Re: Freestyler X2 Universe problem
What type of interfaces are they?
USB? Artnet? Wings?
Does FSX2 see any of them?
Are you running them through a Hub or directly through the mainboard input/outputs?
More information would be helpful
USB? Artnet? Wings?
mjsamarco
I use Usb interfaces.
FSX2 recognizes 2 interfaces, but not at the same time.
- buttza
You might need to work out which com port for each unit.
While it might show as 1 unit it may give you comport options so universe 1 com port 1 Universe 2 Com port 3
