American DJ 12P hex
grimesmichael
- FreeStyler Version: 3.5
American DJ 12P hex
I created a profile for the ADJ 12P Hex, but I need to know if there is any way to get the UV on correctly. When I blackout the system, the UV stays on, because it is not linked to the RGBAW channels as a color channel. It is just placed in there as an extra channel. Any help to get this issue resolved would be greatly appreciated.
topcat
- FreeStyler Version: 1.5.9
Re: American DJ 12P hex
Hello Michael,
did you got the issue resolved? I've also got 2 12P hex and having the same issue.
Best regards,
Kevin
Best regards,
Kevin
- FreeStyler Version: Beta
Just a small comment.
A work around could be to place the UV channel on "CW".
I know that it is intended for cold white but it is only intensity, shutter and color intensity channels which are affected by the black out.
