Eurolite LED MAT-Bar 4x64 RGB DMX
koziolek
I Use FreeStyler for: Band
Post by koziolek »
How to create a fixture to Eurolite LED MAT-Bar 4x64 RGB DMX?
I can not set the control 'left to right' and 'top to down' ..
https://images6.static-thomann.de/pics/ ... ger_uk.pdf
Re: Eurolite LED MAT-Bar 4x64 RGB DMX
Post by Jan_K »
Hej Koziolek
From the look of the DMX table I would place the program and speed on gobo1 and gobo1 rot.
The left - right and the up - down I would place on gobo2 and gobo3
Export the fixture file (pff format) you have at the moment and upload it here then I will try to guide you.
koziolek
Post by koziolek »
Thanks for the response.
I joined the fixture file.
LED MATBar 4x64 RGB.pff
(2.63 KiB) Downloaded 19 times
Post by Jan_K »
I was thinking of something like this.
LED_MAT_Bar_4x64_RGB_V0.pff
(42.77 KiB) Downloaded 30 times
But you need to figure out which way is the best for you to operate it and fit a fixture for this.
