Fixture File Problem: Martin Wizard Extreme Topic is solved
Download other Magic 3D Easy View Fixture files created by the community here.
CLIMBUSA
Post by CLIMBUSA »
Martin Wizard extreme fixture file error? "Wizard Extreme2. fxt: Input past end of file. Fixture has worked in previous FS versions?
WIZARD EXTREME 11CH.ssl2
(26.7 KiB) Downloaded 31 times
dwofford
Re: Fixture File Problem: Martin Wizard Extreme
Post by dwofford »
Did you ever fixture this out?
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
Download the .ssl version of the file. Not the .ssl2 version and see if that works.
Return to “Magic 3D Easy View Fixture Files - User Created Downloads”
