Hello everybody,
I wrote an module for Node.JS which can be used to programmatically set DMX-Values from Node.js in Freestyler. It uses the TCP/IP interface of freestyler.
The project is published at GitHub and is OpenSource.
Have fun using it.
https://github.com/jschyma/FreestylerNodeConnector
https://www.npmjs.com/package/freestyler_node_connector
Known issues:
You can not set more than about 100 DMX-Values at once. Any help regarding this, other issues or additional functions is very welcomed.
Kind Regards
Jens
Freestyler Plugin for Node.JS
- FreeStyler Version: 2
