Rosco I-Cue File Build
DJspeckNC
Post by DJspeckNC »
I have set it up for 2 channel mode (pan/Tilt)but I am unsure what parameters to set for 4 channel mode. One of the other channels should be to turn on/off Auto mode but I can't figure out what the other would be. Attached is the 2 channel version. Thanks for your help and guidance.
I_Cue.pff
(3.74 KiB) Downloaded 26 times
I-Cue_Manual.pdf
(303.26 KiB) Downloaded 37 times
Nathanrs93
FreeStyler Version: None
Re: Rosco I-Cue File Build
Post by Nathanrs93 »
Thanks for sharing :)
