Talent LP64LED-FLAT 5 Channel Topic is solved
proaudiomaster
This light can also be set up for 7 channel
LP64LED-Flat5ch.ssl2- (1.79 KiB) Downloaded 127 times
Nathanrs93
- FreeStyler Version: None
Re: Talent LP64LED-FLAT 5 Channel
Thanks for sharing
Voodootroy
- FreeStyler Version: 3.6.51
Brand new guy here, How do i inport the ssl2 into freestyler?
katokev
- FreeStyler Version: 2
Also a new guy here and following up on this question above. How do you import the ssl2 into freestyler. @voodootroy were you able to figure it out??
Nathanrs93
You don't import SSL2 files into freestyler. Its made for the magic3D, freestyler are different files.
