BCF2000 and Bluetooth remote doesn't work together
studijo
Post by studijo »
I have a BCF2000 and this device work properly with FS in both directions (When I touch the BCF2000, FS changes and vice versa, when I change something on FS, the slider or led indications change on the BCF2000.)
I have also the Bluetooth remote App on my Android device. Also this works also fine but it's only a 1 direction functionality. I can change things on the mobile and FS follows his settings.
I had expect (or hoped) that also the BCF2000 changed this changes from the remote app but this doesn't happen.
Anyone an idea why this happens and it there a solution to let it work all in conjunction?
Thanks in advance!
Freestyler 3.5.9 on Windows 8.1 with DMX4All USB interface.
BCF2000 with firmware 1.10
Fixture setup: 4 x PAR64 controlled by Dimmpack, 2 x Eurolite TSL-200 scanners, 1 x Ayra TDC-33, 1 x Geni FL-1800D strobo, 1 x Antari Z-1500 fog machine
Re: BCF2000 and Bluetooth remote doesn't work together
hi
i think its because the bevolper did not make this Feature.
because the bluetooth/ethernet(android/iPhone) App for FS is a 3-party software/firmware.
and the devolper only made it possible to make a connection between FS and TCP/IP or Windows API.
with a list of commands that can be used.
but you can make a Feature reqeust here: http://www.freestylersupport.com/bugs/main_page.php
Return to “BCF2000”
