I have the following problem:
Get notified by VirtualDJ (set cue point as "FS: 46.1") trigger a Squenze with a strobe effect, which then stops automatically. For Fixurten with a strobe channel that is not a problem. The sequence that we set to no loop and stops automatically after a short time.
Now I have a fixture (LED strips) which has no strobe channel. There are only 3 channels (RGB). My idea was to create the strobe effect with a sequence of very short 2 scenes (ON / OFF).
The problem is that I (ON / OFF) can only run once this sequence, or an infinite loop.
Besthet the possibility of a sequence gestarten from VirtualDJ with a vordefnierten number of iterations to run?
For your help I would be grateful.
Number of loops of a sequence?
Adler
- FreeStyler Version: 3.5.7
