ADJ INNO POCKET ROLL [SOLVED] Topic is solved
adamsnowball
Post by adamsnowball »
Hi I'm brand new to freestyler and have got a new pair of ADJ Inno Pocket Rolls and would love to be able to control them in freestyler now that I have my dmx dongle. Would somebody please be able to help me out with a fixture file?
New fixture update has inno pocket spots but not rolls unfortunately.
I have attached the manual as per the rules of posting,
Many thanks,
Adam
inno_pocket_roll.pdf
inno pocket roll manual
(1.43 MiB) Downloaded 24 times
apollodj
Re: ADJ INNO POCKET ROLL
Post by apollodj »
I've done the best i can,
As there is no listing of pan and tilt degrees, you may need to tweak them in the editor.
This took me 15mins to do, have a crack at the next fixture yourself as they are probably the easiest bit of freestyler to use.
Anywho, see how you get on with this.
I've put in some macros for gobo rotation etc...
Inno Pocket Roll.pff
(95.03 KiB) Downloaded 45 times
adamsnowball
Thank you so much, this fixture file is perfect and so easy to use. I am very happy :-)
hugo27th
Re: ADJ INNO POCKET ROLL [SOLVED]
Post by hugo27th »
thnx, and a little question:-) Can you use this in sound active mode program on dmx?
and master and slave on dmx?
sorry my english:-)
