Running sequence and pan/tilt panel at the same time? Topic is solved
honzamat
Post by honzamat »
Hello,
is it possible to control movement of intelligent heads using the pan/tilt and have a sequence running at the same time?
My idea was to drive the movement of the heads using the pan/tilt panel (predefined curves) and color effects have programmed within the sequence. Is there a way to make the curves and sequences work together in FreeStyler?
I was unable to set this up - when I started any sequence, the pan/tilt panel was stopped. It did not matter what fixtures were part of the sequence (the pan/tilt was stopped even if none of the fixtures within the sequence was controlled by the pan/tilt panel).
Thank you ;)
jab1969
Re: Running sequence and pan/tilt panel at the same time?
Post by jab1969 »
I need an answer to this as well please let me know if you crack it thanks
FreeStyler Version: 4.01
Post by Partyman »
The answer is yes and no. You can only use the predefined movements in sequences. With most other items color, gobo, pan, tilt but movements were designed to be used in sequences. You CAN make sequences for just the movements and different sequences for color or gobo and use them together :)
