Lightmaxx LED Drop II problem
jannispi99
FreeStyler Version: 3.5.8
Post by jannispi99 »
Hello,
I bought a Lightmaxx LED Drop II. I have only the dimmer to 255 and the color red to 255. When I plug this in DMX mode to a control device, everything works. When I use the LED Drop II with the Freestylers flash on individual colors. The problem has to put on freestyle, the device is not defective. As an interface I use a JMS USB2DMX.
Can any one help me to solve the problem so that the colors and built-in programs are no longer flashing / interrupt?
The refresh rate I have also been changed, in this case the curtain flash anyway.
Thank you in advance,
jannispi99
Nathanrs93
FreeStyler Version: None
Re: Lightmaxx LED Drop II problem
Post by Nathanrs93 »
Do you have the manual and the fixture file?
jannispi99
Yes, I have.
jannispi99
Nathanrs93
Well, you'll need upload them and let's have a look and see if we can fix it :)
Make sure you export the fixture file to .pff and the manual is .pdf
jannispi99
Hey, I versteh the fixture file myself. I've tried this with the program DMXControl, there I have no problems. So the problem must be the Freestyler.
jannispi99
Nathanrs93
jannispi99 wrote:Hey, I versteh the fixture file myself. I've tried this with the program DMXControl, there I have no problems. So the problem must be the Freestyler.
Well, if you think it's a bug within the software then fill this out and send it.
[bugreporting][/bugreporting]
