Futurelight Scan SC530 16 Bit
numtek
Just started using FS
FreeStyler Version: 3.6.3
Post by numtek »
All tested and working. I added some macro's, so don't forget to expand the lamp/window/color-windows with the '+' in the lower left corner.
Be sure to set the Futurelight Scan SC530 to 16Bit mode by using the menu at the top of the fixure.
The amount of DMX-channels is different between 8bit and 16bit mode, due to the fact that 16bit requires 4 channels for pan/tilt instead of just two. So if you wondered why the default fixture wasn't working properly, this one is for you.
Based on the orginal fixture created by djsupport who is an admin on this forum. Thanks djsupport!
futurelight_Scan_SC_530_16_Bit.pff
(137.77 KiB) Downloaded 116 times
Return to “Futurelight”
