Animated gif's
Animated gif's
Post by Jan_K »
Hej folks
From time to time I look for gobos and so on.
I found some animated gif's in DMX Pro which may be usable here.
Have a look.
Animated_gif.zip
(4.84 MiB) Downloaded 259 times
Re: Animated gif's
hi jan_k i have taken a look at it seems realy nice only there's a problem.
the animations from FS are made @ a size of 20x20 pixel. gives 400 DMX channels.
the ones you show are @ 60x80 this means 4800 dmx channels. so it will only show a small part from the total gif animation.
and also i have made some gifs my self and i noticed if the gifs are to big it takes forever for FS to load the image.
Re: Animated gif's
Post by Jan_K »
Hej Spirit
I saw the relative large size
4800 X 3. (RGB) so14400 channels. or 29 universes. :D
It is a long time since I last tested the "led trix" but you may be right about the loading time.
My guess is that some of the gif's with low details can be used with a decent result.
Return to “Suntrix & LedTrix plugin”
