Cues wont run?
atdnr
FreeStyler Version: 2x
I Use FreeStyler for: Church
Cues wont run?
Post by atdnr »
Hello,
I've searched the wiki, I've combed through the forum, but I've been unable to find a solution to my problem.
I've patched all of my fixtures.
I've built my sequences.
I've entered my cues.
What I can't seem to to is get a cue to run.
When I click the little "play" button, in the cue pane, I can see it move through the sequence steps, but nothing happens on the desktop, nor my actual fixtures.
What am I missing?
Nathanrs93
FreeStyler Version: None
Re: Cues wont run?
Post by Nathanrs93 »
What interface are you using?
atdnr
Re: Cues wont run?
Post by atdnr »
Enttec open DMX.
But, the % values don't even change on the desktop.
spud1511
FreeStyler Version: 3.5.7
Re: Cues wont run?
Post by spud1511 »
If you open the freestyler output window to view dmx output do you see anything change there?
atdnr
Re: Cues wont run?
Post by atdnr »
No.
I clicked the play button for each cue but the output window info never changed.
Maybe I'm recording the cue wrong?
Create Sequence
Set fixture levels, make sure "fade" is on, (all conventional fixtures at this point - simple fade on or off)
Save as...
Click "Cue"
Click the play button for what I just created,
and nothing happens.
kittmaster
Commited FS Forum helper
FreeStyler Version: 3.6.2
Re: Cues wont run?
Post by kittmaster »
I think it is time that we look at doing some video tutorials....it will make things a lot easier IMO.
