Cameo CLPFLAT1RGB10IR FLAT PAR [SOLVED] Topic is solved
toomuchmetal
Post by toomuchmetal »
Hi all,
I'm pretty new to software lighting (pretty much as of last night).
Does anyone have any experience with The Cameo Flat Pars Spot lights?
I am trying to control them from Reaper, through Midi Yoke, into Freestyler and out through a Velleman K8062.
Although there is no dedicated fixture profile for this light, so I have been controlling with 6 separate Parcan channels.
FreeStyler is receiving the message from Reaper, but the lights don't seem to be doing anything, however when I control the lights directly from FreeStyler or Velleman's test software, they do what I would expect them to.
The lights are 6 channel, with a Dimmer channel, a strobe channel, a red, a green and a blue channel, and I believe the 6th is sound to light.
Could anyone suggest an alternative fixture profile that I could use?
Phil
Nathanrs93
FreeStyler Version: None
Re: Cameo CLPFLAT1RGB10IR FLAT PAR
Post by Nathanrs93 »
I find it's always better and safer to create a actual proper fixture file for it.
Because I'm feeling nice today, here's the fixture, 6 Channel Mode
Iris Channel = Colour Change (Rate)
Focus Channel = Colour Blending (Rate)
Frost Channel = Microphone Sensitivity Control
FLAT PAR CAN RGB 10 IR.pff
(24.23 KiB) Downloaded 47 times
