WECAN WKY-L60 Features?
AthenaProduction.net
FreeStyler Version: 3.4.6
I Use FreeStyler for: Band
Post by AthenaProduction.net »
Hi. I started to build the profile for this light, and I started wondering how to implement the features such as the gobo spin, and the pan-speed setting. Any insight would be great. Thanks.
Re: WECAN WKY-L60 Features?
Post by Jan_K »
There is no dedicated control for Pan / Tilt speed.
Normally I just edit the name in the chanal description tab.
The user can then use the faders in the right side of FreeStyler to control it.
Try upload the fixture you have created (pff file) and I will try to guide you.
