X uDMX interface not working with lights
amarsden2010
Post by amarsden2010 »
http://s1378.photobucket.com/user/Alex_ ... g.html?o=0
installed freestyler 3.4.6 as given by the distributor, tried to install the udmx drivers however a black box appears and cancels the installation, copied the dll file over to windows folder and shows in the device manager however its got a exclamation mark next to it. Any ideas to fix it?Image
spud1511
FreeStyler Version: 3.5.7
Post by spud1511 »
Have you tried installing by following something like this?
http://www.youtube.com/watch?v=OZa44fhQ4WU
Also, you say you got a copy of freestyler from distributor, I would suggest getting the latest version from these forums, think it's currently 3.5.7. So you know for your own peace of mind it's the full clean proper version.
amarsden2010
Re: X uDMX interface not working with lights
tried doing it that way this is what comes up
have also updated the software to 3.5.7 and stiff having issues any other ideas thanks
spud1511
Post by spud1511 »
Ok, I get the impression that message is normal as its unsigned, since it is mentioned in the instructions for udmx installation.
My immediate reaction would be to download a fresh copy of the install / drivers, and work through the instructions here http://www.illutzmination.de/udmxdriver.html?&L=1 slowly and carefully - one line at a time - taking care not to accidentally skip over forget anything.
If that fails there are links on the page to where people have made it work and how, but firstly just working through step by step would be your best starting point.
MusicSync
Post by MusicSync »
I recommend below ArtNet to DMX interface and give up all the USB to DMX dongles.
http://hz.aliexpress.com/store/product/ ... 20451.html
Return to “DMX Interfaces”
