Fade/Snap override
spdj20
Fade/Snap override
Post by spdj20 »
I have a sequence programmed with 8 ADJ Mega Tri Par Profile. The sequence is programmed for snap on all fixtures and steps. What I'm trying to figure out is if there is a way to program an override button to toggle between fade/snap for that sequence. I know if I had a sequence of fades I can disable the fade in the cue window. So is there anyway to make a shortcut to that to be able to toggle fade/snap when running sequences. Ideally I want an override button so I can easily trigger it via MIDI
spud1511
FreeStyler Version: 3.5.7
Re: Fade/Snap override
Post by spud1511 »
Would it be easier to use the 'save as' in the sequence creator to make another copy, then just change one copy to fades? Not exactly what you were asking for I know, but the only obvious other way to do it would be to manually change everything to fades instead, and then use the override you mentioned already when you want it to snap instead of fade.
spdj20
Post by spdj20 »
I tried that, but the override won't work. I can't just create a scene where the RGB colors are snap or fade, because that also records the values of the RGB, which also overrides the other sequence. Selecting disable all fades on the program window submenu also has no effect
