I need a fixture file for the blizzard blade runner RGBW
Manual: http://www.blizzardlighting.com/index.p ... format=raw
I need the 32 channel DMX version.
Thanks so much
Need fixture file for blizzard blade runner rgbw [SOLVED] Topic is solved
- FreeStyler Version: Beta
Re: Need fixture file for blizzard blade runner rgbw
Hej
I just had a quick look on the DMX table and made a fixture which can control one of the lamps.
There need to be created 3 more and they are to be used as a combined fixtures.
The DMX table on the datasheet miss some values.
Channel 19 and 20 are used to control some macros but there is no values for setting these functions off so it is the RGBW channels which are used.
The attached fixture is only a test so you need to figure out the values for channel 19 and 20 and post them.
edoerfel
Hi thanks for the post, however the pan and tilt does not work.. This is one of the most complex fixtures I've delt with so far and am needing some more help!
You have all 32 faders in the fader panel, "right side of Freestyler" by using them it should be possible to control all channals individually and then detect what is wrong.
When I look at the output monitor then pan and tilt are changing values on channel 22 and 23 which is the channals for the first head. (That is what is stated in the data sheet)
Are you sure that you are not running in 14 channel mode.
edoerfel
Okay it was on 14 ch mode. I switched it to 32 cha mode and everything works for the 1st light. I can control the other three from the side fader panel. All the sliders work. Now just how do I get them from the sliders to actual windowed controls...
And one little thing with the first like - I can pan and tilt but the shapes don't work.. Hmmm
Thanks for the help!
I will do the control for the 3 others lights later but can you please verify the two macros.
Please check that they shift to the right function / color and specially how to turn them off again.
That is not stated in the data sheet.
edoerfel
Ya the macros work.
I got Adam Collins to create me a profile for them and I got it working!!
Thanks again for the help! If you want I can still confirm that your profile works when you edit it for anyone else on the forum who might need it who doesn't want to pay for a profile.
edoerfel
http://www.ctwo12.com/freestyler-fixtures/ if where I bought it from
