ADJ VBAR PAK Topic is solved
a.murtagh99
ADJ VBAR PAK
Post by a.murtagh99 »
Hi guys
Just wondering if anyone has / will create a fixture profile for The American DJ VBAR PAK?
Thanks in advance
Andrew ( :fs: )
VBar Pak.pdf
(962.47 KiB) Downloaded 44 times
Re: ADJ VBAR PAK
hi
first of all if you dont add a image from the dmx chart or a PDF file no one will help you.
as i (others) allready know how to do it. and not going to give everything for nothing.
offcourse we will help you if you add a PFF file you made.
create-ing a fixture file is a realy good way to understand how your fixture work.(basics of DMX)
as i dont own/use it i dont need to know.
if i use a new fixture i allways read the the pdf as it can reveal special function a fixture file on FS doesnt have.
so please add a PDF or DMX chart and create at least one fixture file your self.
a.murtagh99
Re: ADJ VBAR PAK
ok will do
djnikkofb
FreeStyler Version: 3.6.X
Re: ADJ VBAR PAK
Post by djnikkofb »
I've spent many hours creating this American DJ vBar Pak. This is for the ADJ 5 Beams. I've only created the 7 channel mode for free. I hope this helps with your basic setup. I also have the full 8 channel DMX mode fully mapped with Gobos, Fixture IMG, etc..
American_DJ_VBAR_Pak 5x7ch (DJ NIKKO).zip
(11.18 KiB) Downloaded 20 times
Sent from my GM1915 using Tapatalk
