Uninstall freestyler bug [SOLVED]
masutrixx
FreeStyler Version: X2
Post by masutrixx »
I cant uninstall freestyler, the configuration-screen tells me it's removed or allready uninstalled before.
Also the Original uninstaller, in the freestyler folder in the start menu doesn't work. (the file uninst001.exe file doesn't exxist ?)
Please help, i want it removed from my computer !!
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Uninstall freestyler bug
Post by buttza »
Please supply the following information:
OS Version
Freestyler DMX Version
masutrixx
Post by masutrixx »
OS: windows 7 home premium 64bit
Freestyler version: Latest stable ? X2 ?
But i used revo uninstaller to uninstall everything, the uninstaller from freestyler just didn't work.
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
HI
Why are you using "Revo Uninstaller" to uninstall the program? Why aren't you just doing it straight from windows, itself?
Regards
Nathan
masutrixx
Post by masutrixx »
@Nathanrs93, because that didn't work. Windows told me that the program already was deleted/uninstalled and asked if i wanted to remove the item from the program-list. The folders and program was stil on my harddrive. So that didn't work, and the uninstaller file also didn't work.
i tried to install the program again, and after that tried to uninstall again. Also didn't work...
So revo uninstaller came in handy, now everything is deleted/uninstalled and i dont ever install it anymore.
If you put software online, make sure it all works perfect......
