14 channel mnin spot need profile Topic is solved
PtownBubba
I have this light from ebay seller,15W LED Spot Light Stage Mini Rotating Light , 14 channel, looks like a Chauvet mini, but I do not find a 14 channel Chauvet fixture/profile,, sorry new here, just getting started with Freestyler, so any advice or help in finding what I need to do would be great.
Nathanrs93
- FreeStyler Version: None
Re: 14 channel mnin spot need profile
Hi
We can't really help you make a fixture file unless we have a DMX chart or manual of the fixture?
Regards
Nathan
Regards
Nathan
PtownBubba
ok,, can I send a PDF somehow with the DMX settings,,, my scanner only saves to pdf.
PtownBubba
I am confused because the booklet that came with light, shows DMX Channel Values [14 Channel ] on one page
Then DMX Channel Values [5 Channel for Spot ]
but the EBAY of my light ad, it was listed under, shows 13 channel,,, not 14 channel ????
☆ 13 channel DMX-512 LED moving yoke color wash
☆ Pan: 540° / tilt: 270°
☆ RGB color mixing
☆ Variable electronic strobe
☆ Variable electronic dimmer (0 to 100%)
☆ Vector speed channel for pan/tilt, RGB color mixing and color macros
☆ Built-in movement macros via master/slave or DMX
☆ Built-in automated programs via master/slave (fast and slow)
☆ Built-in sound activated programs via master/slave
☆ User-selectable basic or advanced operating modes
☆ User-selectable pan/tilt ranges
-Pan: 540°, 360°, 180°
-Tilt: 270°, 180°, 90°
☆ Pan/tilt invert
☆ Beam Angle: 27°
☆ Field Angle: 53°
☆ Lux: 689
☆ Light Source: 15W (700mA x6) RGB LED >50,000hrs
☆ Power and Current: 110V-240V switchable
☆ Weight: 8.37lbs/3.8kg
☆ Size: 6.8" x 6.8" x 9.8"/ 173x173x249mm
Channel Functions:
1.Pan
2.Pan Fine
3.Tilt
4.Tilt Fine
5.Vector Speed:(Normal->Slow)
6.Dimmer/Strobe
7.Red
8.Green
9.Blue
My manual shows White as a fourth color
10.Color Macros
11.Vector Speed(color)
12.Movement Macros
13.Gobo
☆ RGB color mixing
☆ Pan/tilt invert
☆ Beam Angle: 27°
☆ Field Angle: 53°
☆ Lux: 689
Channel Functions:
1.Pan
2.Pan Fine
3.Tilt
4.Tilt Fine
6.Dimmer/Strobe
7.Red
8.Green
9.Blue
10.Color Macros
12.Movement Macros
13.Gobo
spud1511
- FreeStyler Version: 3.5.7
So can't you just set the dimmer channel, and white channel to 100% and see if you get white light through or not?
Nathanrs93
Hi
I'd go with the manual, it's probably the most reliable when it comes to unknown brands on eBay.
Regards
Nathan
Regards
Nathan
PtownBubba
Not sure I have the brains t make a fixture for my mini spot, after I made one, and it did not work, I would,, not know if it was the fixture software, the USB dongle connected to pc and l light, or Win7 64 bit pc conflicts, causing the failure,,,, If possible, I would like someone to create or build fixture software for me,, willing to offer up some $ as well,,,,,zip-file it and post it or email it,,,,,,,,,,,,, is that do-able ??
Nathanrs93
HiPtownBubba wrote:Not sure I have the brains t make a fixture for my mini spot, after I made one, and it did not work, I would,, not know if it was the fixture software, the USB dongle connected to pc and l light, or Win7 64 bit pc conflicts, causing the failure,,,, If possible, I would like someone to create or build fixture software for me,, willing to offer up some $ as well,,,,,zip-file it and post it or email it,,,,,,,,,,,,, is that do-able ??
We can help but like I've said we could real do with a properly manual for the fixture to work from?
Regards,
Nathan
PtownBubba
PtownBubba
Maybe this is a better upload / image,,, I have seen a lot of 13 Channel lights, but mine is a 14 channel, apparently because it has the white [RGBW]
DMX Settings Mini Spot.pdf- 14 and 5 Channel Channel Summary
- (369.08 KiB) Downloaded 72 times
PtownBubba
I am still confused about the 14 channel DMX sheet,,,, on the fixture it self, when scrolling through the mode menu, , I can choose 13 channel, or 5 channel,,,,,,,,,,,, what is the 14 channel declaration at the top of manual,,,,, ????? a printing error from the factory ?????
spud1511
Wrong manual in box? If the light only has 13 channels, and you were not sure if your 13 or 14 channel dmx chart was the one to use I guess that answers your original question.
PtownBubba
This is the light I purchased:
http://www.ebay.com/itm/171360734847?_t ... EBIDX%3AIT
Has anyone else got this light, and found or made a fixture profile for it ?
Now another seller has this one listed , looks exactly the same, but has a slightly different description.
http://www.ebay.com/itm/New-Arrival-15W ... 4ad93aa3cf
Like I said, my fixture says 13 or 5 channels when scrolling the lights control menu,,,, so maybe there is no 14 channel light,,,,,,,,,,,,,, ???? ugh ??????????
I suppose I need to find or have someone create both 13 and 14 ch profiles, and see which one will control the light ?
spud1511
Theres loads of variations of the 'mini video recorder' style of moving heads, lots of which are usually made in the same few production lines, but to different specs and with different spec components, and with other small differences depending on the specifications of the buyer for each different production run.
I would suggest you load 13 single channel generic parcan fixtures into freestyler, set them all to about 50% so whatever channel the dimmer, etc is on you will have light output and just operate one at a time and write down on a piece of paper exactly what happens on each channel.
This will allow you to take a picture/sketch of each gobo to help make your fixture file with, and you will know exactly what channel operates what.
Once you get the hang of freestyler you can also then recycle this pics/info into easyview in the future to create shows without having to setup all your lights every time.
spukemonkey
- FreeStyler Version: 3.5.5
I have this light and mine is 13ch only difference is the white channel but mine has white on the macro channel. as for fixture file I am just finishing mine with the pan/tilt left to do you could change mine with 14ch no problem just have to change the values
