More Than 510 Channels.
Mike_K
FreeStyler Version: x
Post by Mike_K »
Is it possible to have more than 510 output channels ?
I would like to use TM1809 smart strips for accent lighting around our house.
I have several J1sys E1.31 or to DMX output (4 Universes)
I would like to have RGB "Pixals" in freestyler and set groups up: Fence / fountain / outline / trees etc.
Because of the smart strips they are 150 channels per strip. I need to use 32+ strips.
Is there a way to use freestyler for this?
Freestyler to sACN ?
Nathanrs93
FreeStyler Version: None
Re: More Than 510 Channels.
Post by Nathanrs93 »
Remember that Freestyler only has 1 universe available at the moment, so if you need more than 512 channels you will need to look at other software until 2 universes become available on the freestyler software.
