Movinglights and LED Par's Topic is solved
LiamAddams
Post by LiamAddams »
Hi Guy's,
i have a problem with multi sequences. I have different sequences for movinglights and for the led parcans and i want to play one sequence for each at the same time - But when i Switch for example on a strobe program the moving lights and the cans stop in the position and don't get in the blackout mode. Is there a function where i can change this?
Thanks for the support
spud1511
FreeStyler Version: 3.5.7
Re: Movinglights and LED Par's
Post by spud1511 »
Setup, freestyler setup, and there's an option to select multiple cues.
Or read the tutorial on submasters download/file.php?id=1176 may be more use to you if you are attempting to layer things together.
