Fixture with purple color Topic is solved
forno
Post by forno »
Hello everyone,
I'm creating a fixture for the Prolights Lumipix16H, a led bar which has 6 colors total.
I've assigned the RGB channels in the fixture creator, then I've set the amber color and the CW color for white channel.
But, that bar has also a purple channel, and my question is: what's the best way to insert it?
Thanks ;)
Caloute
FreeStyler Version: 3.645
Re: Fixture with purple color
Post by Caloute »
Interested to know to, Partyman? Thanks
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
Freestyler doesn't have a dedicated for purple or UV, the best you can do its just the side bar sliders to control the purple channel.
SiGNe
FreeStyler Version: 4.14
Post by SiGNe »
I used the WW channel but it would be nice if UV would be added.
Yeah, use the custom sliders feature to add purple and UV options....
