American DJ Dual Quad Help
rlenius
FreeStyler Version: 2
I Use FreeStyler for: Church
Twitter: www.twitter.com/tylerlenius
Post by rlenius »
When I select this fixture and the fixture data comes up I see that it has notes that state "7 ch are to be added 4 times to cover 28 ch " Could someone help me understand this. And how to do this. I want to set it up with 28 ch. mode. Thank you!
Re: American DJ Dual Quad Help
Post by Jan_K »
Hej Rlenius
There are a bit more information here about the combined fixtures http://www.freestylersupport.com/wiki/f ... d_fixtures.
The basic for the fixture you want to use is that a FreeStyler fixture only can control one scanner (Pan and Tilt).
The Scanner you have got 4 scanners in one and uses 28 DMX channels.
So you add the FreeStyler Scanner, which only control 1 of 4 scanner, 4 times.
if your scanner starts at address 11 then
Fixture 1 controls channel 11 to 17
Fixture 2 controls channel 18 to 24
Fixture 3 controls channel 25 to 31
Fixture 4 controls channel 31 to 37
