American DJ Inno Spot Pro
1470jq
Post by 1470jq »
This is for the American DJ Inno Spot Pro LED 14 channel dmx light fixure this has been tested
Inno Spot Pro.pff
Oct 2014 14 channel Inno Spot Pro
(172.75 KiB) Downloaded 223 times
freestylerrocks
Re: American DJ Inno Spot Pro
Post by freestylerrocks »
HUGE thanks for the fixture file!!
I noticed the macros don't work. Sound mode, mov 1-12 and the rest in that section don't do anything to the inno spot pro. Is there something I'm missing? Also from reading the manual the inno spot pro doesn't have sound active mode controllable from DMX. Is there something I'm missing?
Thanks so much in advance!
Post by Jan_K »
Hej.
I just had a quick look at the fixture.
There is no values entered in the macro table so you are right that something is missing.
If you need them, then you just have to enter the values.
cyberphox
FreeStyler Version: 3.6.3
Post by cyberphox »
so does anyone have a proper fixture file?
Return to “American DJ”
