Fixture for Chauvet Hive - Help [SOLVED] Topic is solved
kericoul
Post by kericoul »
Hello everyone,
To begin with, sorry for my english, I'm french
I bought several sets of light
I want to use Freestyler, but I have trouble using fixture Creator
Can you help me create the fixture for the Chauvet Hive
as an attachment you will find photos of the manual for the DMX configuration
Thank you to you for your valuable help
Kericoul
Re: Fixture for Chauvet Hive - Help
Post by Jan_K »
The 3 channel version could look like this.
Post by Jan_K »
And the 20 ch version may look like this.
kericoul
Post by kericoul »
thank you very much for your answer.
I tested your configuration when I come back tomorrow night.
I'll post two more questions for my other 2 sets of lights on other new posts
thank you very much to you for your help
kericoul
Post by kericoul »
Hello there,
I tested your fixture, it does not work.
I test in 3 channels configuration:
- There are only the pod 6 that glows
- On / Off lamp is not working
- The strobe is not working
- Same thing for automatics program
Any idea? thank you
Post by Jan_K »
If only one of the pod is glowing then I sounds like your light is running in 20 channel mode and not 3 channel mode.
You are to set that in your fixture. There is a menu point where it can be set to 3 or 20 channel mode.
The "Open / Closed" button are not suppose to be shown in the panel as no values are on these.
It is an error or the way FreeStyler lamp panel is created so it don't work.
You could place channel 1 on the shutter channel and then give closed the value "0" and open the value "12". Then at least something happens when you press the buttons.
Post by Jan_K »
Chauvet_Hive_03ch.pff
(23.64 KiB) Downloaded 52 times
Chauvet_Hive_20ch.pff
(13.95 KiB) Downloaded 62 times
kericoul
Post by kericoul »
thank you for your reply.
I'll test your fixture tonight or tomorrow.
this is very nice
kericoul
Post by kericoul »
Hello there,
I just tested your fixture Hive 20 channels.
It works very very well
All functions are working properly
Now I have to settle for integrated programs
Thank you very much for your contribution
