Magic 3D Easy View color not changing
Magic 3D Easy View Stages built by the FS Community these may help you test your lights in other enviroments or just for practice.
alexandre.beli
FreeStyler Version: 3.5.7
Post by alexandre.beli »
Hi experts.
I'm facing problems when changing color in Freestyler fixture and it doesn't reflect changes in Magic 3D Easy View.
I have tried to use Blizzard Flurry Q in Freestyler and Magic 3d Easy View and I only can move Pan and Tilt, but none of the color features are available.
It's impossible to change colors and i'm becaming crazy trying alternatives on this.
I checked the DMX addresses and tried to create other scenario with only Par Led and nothing happens.
I use Freestyler 3.5.7 and Magic 3D downloaded from the site and working with FS. Any DMX address and value is being reflected in Magic 3D Easy View.
Thanks for your support !
Alexandre.
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Magic 3D Easy View color not changing
Post by buttza »
The fixture profile from M3DEV my not have been setup correctly with the colour changing values. I have used this program a lot an have found that you may need to copy the existing fixture file and edit it in the fixture creator and check the colour wheel values.
It can be a tricky process. :)
Alternatively you can go to http://www.nicolaudie.com/en/ssl.htm and see if they have the fixture file there and import it into M3DEV. Check the channel modes too. Make sure they line up with FS Fixture file. :)
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
What he said ^^^^
Couldn't have explained it better myself :lol:
Return to “Magic 3D Easy View Stages”
