DMX values strange on startup
Edgar
FreeStyler Version: 2.96j
Post by Edgar »
I'm having a strange problem with FS 1.96j.
I added all my fixtures and saved my location, when I looked at my output data, everything was zero and ok.
When I opened FS at a later time, my output was 224 at dmx ch1, 225 at dmx ch2, 226 at dmx ch3, and so on till 255 at channel 32. All the later dmx channels have the value off 255. Now I can only change the value of a dmx channel between this 'start adress' and 255. For example channel 1 between 224 - 255, and channel 2 between 225 - 255. Channel 32 and further are not to change at all!
Is there anyone who knows about this issue and is having a solution?
Thanks for your support!
Edgar
Android Dev (Moderator)
FreeStyler Version: BETA
Re: DMX values strange on startup
Post by Mattotone »
try this.
Setup-> freestyler Setup -> Prefrences -> correction
Ensure all values are 0
Edgar
Post by Edgar »
Checked that allready, thanks. It seemed like everything went wrong in FS, when I quitted and started up again, all my fixtures, except the first, where gone. Sequences didn't work etc. etc. I removed FS and installed again, today everything works fine, don't know for howlong....
