Hi all,
it is possible to create macro which send value for set time?
I want to send value 255 to channel 1 for 5 seconds to make RESET of my Martin Mania SCX600.
Thank you
David
sending value for time [SOLVED]
dave.a
- FreeStyler Version: 3.5.5
- Spirit
- FreeStyler Version: 3.5.9
Re: sending value for time
hi if you add the Reset value+channel to the fixture file it should send the Value for 6sec.
dave.a
Thank you very much.
David
David
