I created a wrapper library for sequences and cues to use with a cue stacking program/plugin. I figured I would post it, in case anybody else is interested.
It reads in cue files (FCF) and generates .NET objects with those options. Currently the library only supports reading in files - no writing yet. I will post subsequent versions here.
Most of my development is for in-house apps - I have never sent stuff out in the wild before. So if you have any comments or suggestions (that are constructive - "Hey dude, this sucks" doesn't really help) to improve it, please let me know.
A generated .CHM help file is included for documentation. Thanks to mattotone for his FreeStylerConnection library.
Freestyler .NET Wrapper Library Topic is solved
ewdieckman
FreeStylerLibrary_v1.0.zip- Version 1.0 - Released 6/27/2014
- (123.42 KiB) Downloaded 158 times
chriske
Re: Freestyler .NET Wrapper Library
Hi! First of all thank you for sharing this!
I am very interested in your libary, although i don't completly understand it
Maybe you have a little example to show us how it works? I would be happy to use your libary in my application!
ewdieckman
I'll use some examples from the Cue-ing program I wrote (called LiveCue). Let me know if this helps:
Let me know if that's enough to get you started.
Code: Select all
Dim cueF As FSCueFile = FSCueFile.LoadFCF("C:\FreeStyler\Cues\Songs N-Z\Slither Intro.fcf")
Dim sequenceNumber As Int16 = 0
Dim cue As FSCue
For Each cue In cueF.Cues
sequenceNumber = cueF.Cues.IndexOf(cue)
Console.WriteLine(String.Format("Sequence {0} path: {1}", sequenceNumber, cue.Sequence.Path))
Console.WriteLine(String.Format("Sequence {0} looped: {1}", sequenceNumber, cue.Loop))
'etc - cue has all the properties available to the end user for a cue line (sequence) in a cue
Next
'you can either send the cue as-is, or manipulate values and then send to Freestyler
'stop all sequences - in case there are sequences already running
For sequenceNumber = FSConstants.FIRST_SEQUENCE_NUM To FSConstants.TOTAL_SEQUENCES_IN_CUE - 1
FSCommandUtil.StopSequence(sequenceNumber )
Next
'loop thru and "load up" freestyler with the sequences from the .FCF file and set all options
If cue IsNot Nothing Then
'load cue into FreeStyler
FSCommandUtil.LoadCue(cue.SequenceLoadCommand(sequenceNumber))
'set cue options
FSCommandUtil.LoadCueOptions(cue.SequenceOptionsCommand(sequenceNumber))
'set cue speed
FSCommandUtil.SetCueSpeed(sequenceNumber, cue.SpeedCommand)
End If
Next
'loop through all sequences - if a cue exists, start it.
If sequenceNumber < cueF.Cues.Count Then
cue = cueF.Cues(sequenceNumber)
'send the command to freestyler to play the sequence
FSCommandUtil.PlaySequence(sequenceNumber)
End If
End If
Next
