loop cue
FALCETTA
FreeStyler Version: 3.5.6
loop cue
Post by FALCETTA »
Hello, I wanted to know one thing, it is possible to go to the auto loop certain cue? I mean I have 5 cue 1,2,3,4,5 I can decide to go in a continuous loop automatic cue for example 2:05?, the only option I've found is "all loop sequence" but this option does operate all of the cue in the list ..
thank you very much
FreeStyler Version: 4.01
Re: loop cue
Post by Partyman »
there is a loop option on each sequence in the cue window
FALCETTA
Re: loop cue
Post by FALCETTA »
Where can I find the option cycle? I tried to squeeze play and stop (starting at loop sequences) but still go all the sequences postresti .. I attach a picture?
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: loop cue
Post by buttza »
Is this what you are looking for?
See below Image.
Re: loop cue
Post by Jan_K »
The options are also listed here.
http://www.freestylersupport.com/wiki/p ... k_sequence
FALCETTA
Re: loop cue
Post by FALCETTA »
thanks for the replies.
on the wiki site not found what I was looking for.
No I mean in cue options, there is an option that is called to loop sequences, and makes it go cue automatically one after the other, but I wanted to know if there is a way to choose which cue to use
FALCETTA
Re: loop cue
Post by FALCETTA »
up
FALCETTA
Re: loop cue
Post by FALCETTA »
up
spud1511
FreeStyler Version: 3.5.7
Re: loop cue
Post by spud1511 »
You mean like pressing play on the cue you want to use?
Or assign it to button and add a keyboard shortcut
FALCETTA
Re: loop cue
Post by FALCETTA »
no, I saw that there is a loop function to cue, cue runs one after another endlessly, I wanted sapee if you can choose which cue to go in loop ..
Thank you
Re: loop cue
Post by Partyman »
You build the Cues with the sequences you want in whatever order you want. Then it is your choice as to what each sequence does. The Picture above shows it pretty well
FALCETTA
Re: loop cue
Post by FALCETTA »
I know no one help?
FALCETTA
Re: loop cue
Post by FALCETTA »
help
buttza
Re: loop cue
Post by buttza »
Have you tried building your cues through the submasters? You might need to do that. That is how I do mine and then save them to an actual cue button. I am pretty sure the Freestyler DMX wiki has info on how to do this.
Re: loop cue
Post by Jan_K »
FreeStyler don't have a loop with this functionality you want but can you try to explain what you want to do a bit more detailed so can we eventually guide you to way to build you show so you get the wanted effect.
