question cue
FALCETTA
FreeStyler Version: 3.5.6
question cue
Post by FALCETTA »
Hello everyone, I came from bulgaria dmx usb interface tonight :) I've done some testing, I have a question (I hope at least answer me this) my question is this ..
Let's say I have 2 cues one set of LED par and 2 for a moving head ..
then I put in play the cue 1 (par led) then I want to go to the mobile head, then stoppo cue 1 and cue 2 I play in, BUT the cue 1 (ie, par), I remain always on, is this normal? does not seem like a very pleasant thing .. if I wanted that when a cue stoppo its headlights turned off as I do?? thank you very much
malykazio
Re: question cue
Post by malykazio »
It's normal behavior. You turn on the lights, so you should turn them off. Stopping cue doesn't turn off anything.
Simplest way:
At first step of second sequence set all unused values to zero (move sliders to right then to left for to be sure, they are setted to zero)
I always start programming each new sequence from setting all values to zero.
In other way - I think if in fixture configuration is "default value" set to 0 - then stopping cue should turn off the lights, but i,m not sure. I have to check it.
FALCETTA
Re: question cue
Post by FALCETTA »
thank you very much for your reply.
you mean the first step of each sequence to set it all off? you give me an example?
Where can I find the default value? controllarco you? thank you very much ..
