Cue Manager, lights won't change when open
TechHeadSteve
Post by TechHeadSteve »
I am very new to freestyler & finding it hard.
I am trying to set up sequences for use in the Cue manager.
I set the first color, & click the + add to sequence.
But now when I try to change my light colours I cannot.
They will not change colour until I exit the Sequence dialogue box.
Which means I can't create sequences, any ideas?
FreeStyler Version: 4.01
Re: Cue Manager, lights won't change when open
Post by Partyman »
Make sure you don't have the cue window open or running when trying to program cues. If It says "offline mode" then changes will not be visible
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
If your Cue window is open when you open the Sequence window, it runs in 'Offline Mode' which is like 'Blind' on some of the other Consoles and software.
Changes are not visible until you save the sequence.
This is useful if you have to make a slight adjustment while Live. :)
As per what Partyman said. :)
