Chauvet TechnoStrobe168
miked
FreeStyler Version: 3.5.4
Post by miked »
This is a basic 2-channel profile for the Chauvet TechnoStrobe168. The fixture profile included in the latest release is a 3-channel profile for the old TechnoStrobe (rectangular flat pane) and didn't work properly with the 2-channel TechnoStrobe168. It works perfectly for strobe rate and dimmer. This profile has no functionality for sound activated because I don't use that function in this light. The attached Zip file contains the fixture file and the .gif for the image.
chauvet_technostrobe168.zip
(2.76 KiB) Downloaded 169 times
miked
Re: Chauvet TechnoStrobe168
Post by miked »
Was I supposed to post this as a ".pff" file? How do I do that? I'm still learning...actually, I just started. Can you tell?
I think I figured it out. Zipped PFF attached.
TechnoStrobe168_PFF.zip
(2.64 KiB) Downloaded 162 times
Return to “Chauvet”
