Setting time Topic is solved
mary
Setting time
Post by mary »
Hello guys!
I recently downloaded Freestyler and i want to use it to control 1RGB LED light using a USB pro (Enttec). What i want to do is to set the timer to almost 30ms to open and close automatically (where is the time controlled?) .Is this possible to set it in this small scale?..
Any information will be helpful.
Thank you :)
Nathanrs93
FreeStyler Version: None
Re: Setting time
Post by Nathanrs93 »
Time can be set via the cue list
