hi people.
is there any possible way to run more than one sequence at a time so the latest does not stop the previous?
for instance if i program a sequence for a par can chase that is looped, i then program a sequence for a moving head to be moving around say over 10 scenes.
i would like to run the moving heads sequence but continue to run the par can sequence however running the latter stops the first.
is there any fix for this or workaround?
thank you
run more than on sequence? Topic is solved
Nathanrs93
- FreeStyler Version: None
Re: run more than on sequence?
When in freestyler, go setup, then extra options. You then need to make sure "multicue" is always on by ticking the box and then save.
