I'm curious someone can help me with this issue. I'm trying to DMX control my "No Name" Chinese mini moving head 7*12W (see attachment). It have 12 channels (fixed). First of all I started with a similar fixture called Blizzard Flurry-Q 12ch. No response on MH. Started to create my own fixture by fixture creator based on settings in manual. No response at all on MH. Address was set to 001. My interface (uDMX) is working fine with my Eurolight TS-7B scans so that's not the issue. Switched also + and - pole on dmx-in (known issue on cheap Chinese MH's) but also not a solution. I own 4 pieces of these MH's and all show the same behavior. Any clue ?
Many thnx for your help!
Fixture issue mini moving head 7x12W [SOLVED] [DMX issue]
- FreeStyler Version: 3.5.5
Re: Fixture issue mini moving head 7x12W
** FIXED** DMX connection within the MH was connected wrong. + (pin3) and - (pin2) were switched (black and white cable). After change this MH's are working fine with Freestyler and custom fixture ! So everyone with issues please check DMX connections INSIDE Mini Moving Head first
- FreeStyler Version: 3.5.2
Re: Fixture issue mini moving head 7x12W [SOLVED] [DMX issue]
have you a fixture file thanks
