I broke it... HELP!
marzvt
FreeStyler Version: 2.96j
I broke it... HELP!
Post by marzvt »
Ok I am using a Velleman K8062 with windows Vista. I was running 2.95F with fixtures that I created in the fixture creator for my intimidator 1.0s and led lights.
I installed 2.96J over it, when I tried to control the lights nothing happened they. uninstalled everything end deleted the folder and reinstalled and the same thing happened. The weird thing was when I reistalled, My settings and custom files were all there that I thought I deleted. I think these old files are also why my lights stopped working. How can I get rid of everything so I'm starting from scratch, or is there anything else I can do to fix this? Thanks
2.20 Intel Core 2 Duo T7500 3070MB Ram, Vista premium, Velleman K8062 Interface
marzvt
Re: I broke it... HELP!
Post by marzvt »
Ok I fixed it. I defragmentent the drive thinking the program might be re addressing deleted files then I installed to a new folder for good meature. My old settings and files no longer showed up and I am all good everything is working!
