I have already asked this question under a separate topic, but it was at the bottom of an unrelated thread, so may have been missed.
Simple question - how do I set up multiple realtime scheduled events in FS? I'm sure it must be very simple!
Here's a typical scenario:
I want all the fixtures off for most of the day, then to go red for 5 minutes at 17.00. I assume I should therefore set a cue timed for 17.00 to turn them all red, then set a second cue timed for 17.05 to turn all the fixtures off? Individually those 2 sequences work fine, but when I add them to the cue page the off command seems to override the on command, so I get nothing. I'm probably going about it the wrong way, but I'd be grateful if someone could explain how it should be done.
Real time scheduling - how to set up? [SOLVED]
- Just started using FS
- FreeStyler Version: 3.5.5
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Real time scheduling - how to set up?
You have it right. The 2nd cue should not be playing untill 17.05.00. Is it playing? Take a screen shot n we can c if anything is amiss
Sorted. I discovered that I'd set up the sequences as transparent. If I set them up as static it works perfectly. Many thanks.
