Hey,
I have some chinese 152 led Moving Head fixtures that have an issue that I can't seem to fix.
They only work properly when the thing generating the dmx signal is outputting less than 256 channels.
Like for example, a 192 channel cheap lighting desk.
As soon as it goes over that the lights constantly swap between 0 and 255 values across every channel.
I've tested this with my DMX King USB-DMX and their testing program.
Any hints on fixing this? Or restricting the channel output in freestyler to 256? Otherwise Im restricted to cheapy lighting desks.
Also anyone else had any issues with these?
http://www.ebay.com.au/itm/RGB-LED-Movi ... 695&_uhb=1
thanks
Chinese Moving Head problem Topic is solved
