entered teh Right IP but nothing happens
Can´t Connect
Stefan84
- Just started using FS
- FreeStyler Version: 3.5.5
- buttza
- FreeStyler Version: 3.6.4
Re: Can´t Connect
Make sure you check your firewall settings. Also when you connect there should be an icon in I think the top right corner of the screen.
Stefan84
Re: Can´t Connect
wehn i connect with android it works
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Can´t Connect
Because android is awesome lol.
In freestyler before connect with iphone right click the connection icon in fs and select disconnect all.
ensure the correct ip is used. you can type ipconfig into cmd prompt and use the local ipv4 value for this.
Also check out the trouble shooting tool in the android section.
